Ir para o conteúdo principal
Fujifilm Endeavor 100ix Battery Door Replacement
O que você precisa
  1. Fujifilm Endeavor 100ix Battery Door Replacement, Battery Door: passo 1, imagem 1 %32
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  2. Fujifilm Endeavor 100ix Battery Door Replacement: passo 2, imagem 1 %32
    • Locate the battery door.
  3. Fujifilm Endeavor 100ix Battery Door Replacement: passo 3, imagem 1 %32
    • Locate the latch on the battery door.
    • Use your finger pry to it open where it says "BATT."
  4. Fujifilm Endeavor 100ix Battery Door Replacement: passo 4, imagem 1 %32
    • Remove the battery from the camera by pulling the battery door outward.
  5. Fujifilm Endeavor 100ix Battery Door Replacement: passo 5, imagem 1 %32
    • Locate and remove three black 3.80mm screws on the back of the black casing with the Phillips #00 screwdriver.
  6. Fujifilm Endeavor 100ix Battery Door Replacement: passo 6, imagem 1 %32
    • Squeeze the camera placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
  7. Fujifilm Endeavor 100ix Battery Door Replacement: passo 7, imagem 1 %32 Fujifilm Endeavor 100ix Battery Door Replacement: passo 7, imagem 2 %32
    • Locate and remove the 3.80mm screw that holds the plastic strip to the camera body with a Phillips #00 screwdriver.
    • The plastic strip will now come off the camera body.
Conclusão
Eric Nicolai
Membro desde: 01/10/11
679 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 13-5, Forte Winter 2011 Membro de Cal Poly, Team 13-5, Forte Winter 2011
CPSU-FORTE-W11S13G5
Membros da 5
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 1,863
