Ir para o conteúdo principal
FujiFilm FinePix S5100 Microphone Replacement
O que você precisa
  1. FujiFilm FinePix S5100 Microphone Replacement, Battery: passo 1, imagem 1 %32
    • Ensure your camera is in the off position.
    • Orient the camera upside down with the lens facing to the left and the battery compartment facing directly toward you.
    • Open the battery door by pushing down and in the direction of the arrow on the door.
  2. FujiFilm FinePix S5100 Microphone Replacement: passo 3, imagem 1 %32
    • Remove four AA batteries from the camera.
  3. FujiFilm FinePix S5100 Microphone Replacement, Back Cover: passo 4, imagem 1 %32
    • Turn the camera so the screen is facing you and the camera lens is facing away from you.
  4. FujiFilm FinePix S5100 Microphone Replacement: passo 5, imagem 1 %32 FujiFilm FinePix S5100 Microphone Replacement: passo 5, imagem 2 %32 FujiFilm FinePix S5100 Microphone Replacement: passo 5, imagem 3 %32
    • Remove two 0.9mm Phillips #000 screws from the right side of the camera.
    • Remove one 0.6mm Phillips #000 screw from the left side of the camera.
    • Remove two 0.6mm Phillips #000 screws from the bottom side of the camera.
    • When replacing the back cover on the camera, there will be an audible click which ensures the cover has completely seated with the rest of the camera.
  5. FujiFilm FinePix S5100 Microphone Replacement: passo 6, imagem 1 %32 FujiFilm FinePix S5100 Microphone Replacement: passo 6, imagem 2 %32 FujiFilm FinePix S5100 Microphone Replacement: passo 6, imagem 3 %32
    • Carefully pull the back cover and separate it from the rest of the camera body.
    • Carefully flip up the top of the tan colored tab to disconnect the ribbon cable and completely remove the back cover.
  6. FujiFilm FinePix S5100 Microphone Replacement, LCD Screen: passo 7, imagem 1 %32 FujiFilm FinePix S5100 Microphone Replacement, LCD Screen: passo 7, imagem 2 %32
    • Remove the two 1.3mm Phillips #000 screws from the LCD frame.
  7. FujiFilm FinePix S5100 Microphone Replacement: passo 8, imagem 1 %32 FujiFilm FinePix S5100 Microphone Replacement: passo 8, imagem 2 %32
    • Carefully using your hand, grab the LCD screen and pull upward and away from the motherboard.
    • Carefully using your hand, remove the tan digital tape by disconnecting it from the receiving port.
    • Remove the entire LCD screen from the motherboard.
  8. FujiFilm FinePix S5100 Microphone Replacement, Battery Compartment: passo 9, imagem 1 %32 FujiFilm FinePix S5100 Microphone Replacement, Battery Compartment: passo 9, imagem 2 %32 FujiFilm FinePix S5100 Microphone Replacement, Battery Compartment: passo 9, imagem 3 %32
    • Remove the single 1.3mm Phillips #000 screw.
    • Carefully remove the battery compartment from the rest of the camera.
  9. FujiFilm FinePix S5100 Microphone Replacement, Motherboard: passo 10, imagem 1 %32 FujiFilm FinePix S5100 Microphone Replacement, Motherboard: passo 10, imagem 2 %32
    • Carefully grab and remove the upper level motherboard from the camera.
  10. FujiFilm FinePix S5100 Microphone Replacement: passo 11, imagem 1 %32
    • Remove three 0.8mm Phillips #000 screws from the motherboard.
  11. FujiFilm FinePix S5100 Microphone Replacement: passo 12, imagem 1 %32 FujiFilm FinePix S5100 Microphone Replacement: passo 12, imagem 2 %32
    • Carefully remove the tan digital tape from the receiving port.
  12. FujiFilm FinePix S5100 Microphone Replacement: passo 13, imagem 1 %32
    • Carefully remove the lower level motherboard from the camera and set aside.
  13. FujiFilm FinePix S5100 Microphone Replacement, Lens Compartment: passo 14, imagem 1 %32 FujiFilm FinePix S5100 Microphone Replacement, Lens Compartment: passo 14, imagem 2 %32
    • Remove three 1.0mm Phillips #000 black screws from the back of the lens compartment.
    • Remove two 0.4mm Phillips #000 red screws from the back of the lens compartment.
  14. FujiFilm FinePix S5100 Microphone Replacement: passo 15, imagem 1 %32
    • Carefully grab the metal brace and push upward to lift the metal brace off of the hook.
  15. FujiFilm FinePix S5100 Microphone Replacement: passo 16, imagem 1 %32
    • Carefully remove the lens compartment from the camera body.
  16. FujiFilm FinePix S5100 Microphone Replacement, Microphone: passo 17, imagem 1 %32
    • Carefully grab the microphone and cable and remove from the camera.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 161
