Ir para o conteúdo principal
FujiFilm FinePix S4500 Viewfinder Replacement
O que você precisa
  1. FujiFilm FinePix S4500 Viewfinder Replacement, LCD: passo 1, imagem 1 %32
    • Remove the two 3.5 mm Phillips #1 screws in these positions on the left side of the camera with a screwdriver.
  2. FujiFilm FinePix S4500 Viewfinder Replacement: passo 2, imagem 1 %32
    • Remove the three 3.5 mm Phillips #1 screws in these locations on the bottom of the camera with a screwdriver.
  3. FujiFilm FinePix S4500 Viewfinder Replacement: passo 3, imagem 1 %32
    • Remove the four 3.5 mm Phillips #1 screws in these positions on the right side of the camera with a screwdriver.
  4. FujiFilm FinePix S4500 Viewfinder Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to separate the back panel from the camera on the left side.
  5. FujiFilm FinePix S4500 Viewfinder Replacement: passo 5, imagem 1 %32
    • Use a plastic opening tool to separate the back panel from the camera on the bottom.
  6. FujiFilm FinePix S4500 Viewfinder Replacement: passo 6, imagem 1 %32 FujiFilm FinePix S4500 Viewfinder Replacement: passo 6, imagem 2 %32
    • Use a plastic opening tool to separate the back panel from the camera on the left side, then remove the back panel from the camera.
  7. FujiFilm FinePix S4500 Viewfinder Replacement: passo 7, imagem 1 %32
    • Use a plastic opening tool to separate the LCD screen from the camera.
  8. FujiFilm FinePix S4500 Viewfinder Replacement: passo 8, imagem 1 %32 FujiFilm FinePix S4500 Viewfinder Replacement: passo 8, imagem 2 %32
    • Flip up the black tab holding the LCD ribbon wire in place and remove wire.
  9. FujiFilm FinePix S4500 Viewfinder Replacement, Viewfinder: passo 9, imagem 1 %32 FujiFilm FinePix S4500 Viewfinder Replacement, Viewfinder: passo 9, imagem 2 %32
    • Remove the highlighted 2.7 mm Phillips #1 screws to release the metal cover.
  10. FujiFilm FinePix S4500 Viewfinder Replacement: passo 10, imagem 1 %32
    • Turn the camera on its side and remove the highlighted 2.7 mm Phillips #1 screws.
  11. FujiFilm FinePix S4500 Viewfinder Replacement: passo 11, imagem 1 %32
    • Lift and remove viewfinder cover
  12. FujiFilm FinePix S4500 Viewfinder Replacement: passo 12, imagem 1 %32
    • Use the plastic opening tool to remove the ribbon wire from inside the camera
  13. FujiFilm FinePix S4500 Viewfinder Replacement: passo 13, imagem 1 %32
    • Remove the viewfinder assembly from the camera
Conclusão
Uma outra pessoa concluiu este guia.
Vicente Rios
Membro desde: 01/25/17
708 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 9-4, Banghart Winter 2017 Membro de Cal Poly, Team 9-4, Banghart Winter 2017
CPSU-BANGHART-W17S9G4
4 Membros
Autoria de 11 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 15
Ao todo: 995
