Ir para o conteúdo principal
FujiFilm FinePix A340 Motherboard Replacement
O que você precisa
  1. FujiFilm FinePix A340 Motherboard Replacement, Outer Case: passo 1, imagem 1 %32
    • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
    • Slide the battery cover to the side to release the batteries.
  2. FujiFilm FinePix A340 Motherboard Replacement: passo 2, imagem 1 %32 FujiFilm FinePix A340 Motherboard Replacement: passo 2, imagem 2 %32 FujiFilm FinePix A340 Motherboard Replacement: passo 2, imagem 3 %32
    • Remove the five screws from the camera casing using a tri-point Y0 screwdriver.
  3. FujiFilm FinePix A340 Motherboard Replacement: passo 3, imagem 1 %32 FujiFilm FinePix A340 Motherboard Replacement: passo 3, imagem 2 %32
    • Grab the case with your hands and slowly pull back the outer casing.
  4. FujiFilm FinePix A340 Motherboard Replacement, LCD Screen: passo 4, imagem 1 %32
    • Locate the LCD screen and anchoring screw.
    • Remove screw.
  5. FujiFilm FinePix A340 Motherboard Replacement: passo 5, imagem 1 %32
    • Carefully pull the LCD screen away from the board it is connected to.
  6. FujiFilm FinePix A340 Motherboard Replacement: passo 6, imagem 1 %32
    • Push both blue switches away from the holding device to detach the LCD ribbon.
    • Be careful when removing the ribbon. If you damage it, you will need to replace it as well.
  7. FujiFilm FinePix A340 Motherboard Replacement: passo 7, imagem 1 %32
    • Carefully detach the ribbon from where it was connected by the blue pins.
  8. FujiFilm FinePix A340 Motherboard Replacement: passo 8, imagem 1 %32
    • Now that everything has been disconnected from the board, remove LCD screen.
  9. FujiFilm FinePix A340 Motherboard Replacement, Motherboard: passo 9, imagem 1 %32
    • Remove the two screws holding the circuit board down.
  10. FujiFilm FinePix A340 Motherboard Replacement: passo 10, imagem 1 %32 FujiFilm FinePix A340 Motherboard Replacement: passo 10, imagem 2 %32
    • Remove the black sticky tape from the circuit board and camera case.
  11. FujiFilm FinePix A340 Motherboard Replacement: passo 11, imagem 1 %32 FujiFilm FinePix A340 Motherboard Replacement: passo 11, imagem 2 %32
    • Gently pull the circuit board away from the front side of the camera.
    • Be careful when removing the assembly as to not break any solder leads or damage the lens assembly.
  12. FujiFilm FinePix A340 Motherboard Replacement: passo 12, imagem 1 %32 FujiFilm FinePix A340 Motherboard Replacement: passo 12, imagem 2 %32
    • Remove the motherboard by pulling it straight away from the assembly.
Conclusão
Cody
Membro desde: 04/18/10
47 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 7-11, Maness Spring 2010 Membro de Cal Poly, Team 7-11, Maness Spring 2010
CPSU-MANESS-S10S7G11
3 Membros
Autoria de 4 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 13
Ao todo: 3,902
