Ir para o conteúdo principal
FujiFilm FinePix A340 LCD Screen Replacement
O que você precisa
  1. FujiFilm FinePix A340 LCD Screen Replacement, Outer Case: passo 1, imagem 1 %32
    • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
    • Slide the battery cover to the side to release the batteries.
  2. FujiFilm FinePix A340 LCD Screen Replacement: passo 2, imagem 1 %32 FujiFilm FinePix A340 LCD Screen Replacement: passo 2, imagem 2 %32 FujiFilm FinePix A340 LCD Screen Replacement: passo 2, imagem 3 %32
    • Remove the five screws from the camera casing using a tri-point Y0 screwdriver.
  3. FujiFilm FinePix A340 LCD Screen Replacement: passo 3, imagem 1 %32 FujiFilm FinePix A340 LCD Screen Replacement: passo 3, imagem 2 %32
    • Grab the case with your hands and slowly pull back the outer casing.
  4. FujiFilm FinePix A340 LCD Screen Replacement, LCD Screen: passo 4, imagem 1 %32
    • Locate the LCD screen and anchoring screw.
    • Remove screw.
  5. FujiFilm FinePix A340 LCD Screen Replacement: passo 5, imagem 1 %32
    • Carefully pull the LCD screen away from the board it is connected to.
  6. FujiFilm FinePix A340 LCD Screen Replacement: passo 6, imagem 1 %32
    • Push both blue switches away from the holding device to detach the LCD ribbon.
    • Be careful when removing the ribbon. If you damage it, you will need to replace it as well.
  7. FujiFilm FinePix A340 LCD Screen Replacement: passo 7, imagem 1 %32
    • Carefully detach the ribbon from where it was connected by the blue pins.
  8. FujiFilm FinePix A340 LCD Screen Replacement: passo 8, imagem 1 %32
    • Now that everything has been disconnected from the board, remove LCD screen.
Conclusão
Cody
Membro desde: 04/18/10
47 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 7-11, Maness Spring 2010 Membro de Cal Poly, Team 7-11, Maness Spring 2010
CPSU-MANESS-S10S7G11
3 Membros
Autoria de 4 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 9
Ao todo: 6,156
