Ir para o conteúdo principal
Fugoo Tough XL Motherboard Replacement
O que você precisa
  1. Fugoo Tough XL Motherboard Replacement, Case: passo 1, imagem 1 %32
    • Remove the four 3 mm screws located in each corner using a 3 mm Hex screwdriver.
  2. Fugoo Tough XL Motherboard Replacement: passo 2, imagem 1 %32 Fugoo Tough XL Motherboard Replacement: passo 2, imagem 2 %32
    • Gently pull up and off the outer casing.
    • Do not feel afraid to use a bit of force if necessary.
  3. Fugoo Tough XL Motherboard Replacement: passo 3, imagem 1 %32 Fugoo Tough XL Motherboard Replacement: passo 3, imagem 2 %32
    • Remove the internal device from the outer casing.
    • Remove the four 12 mm screws on each corner using a T10 Torx screwdriver.
    • Remove the eight 6 mm screws on the top and bottom using a T10 Torx screwdriver.
  4. Fugoo Tough XL Motherboard Replacement: passo 4, imagem 1 %32 Fugoo Tough XL Motherboard Replacement: passo 4, imagem 2 %32 Fugoo Tough XL Motherboard Replacement: passo 4, imagem 3 %32
    • Use your hands to gently remove the side plates.
    • Use an opening tool to pry off the back plate with the Fugoo trademark.
  5. Fugoo Tough XL Motherboard Replacement: passo 5, imagem 1 %32
    • Slowly pull the front casing from the back casing. Avoid putting any tension on the connected cables.
    • Separate the two slowly and consistently to avoid damaging the speaker cables.
  6. Fugoo Tough XL Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 Fugoo Tough XL Motherboard Replacement, Motherboard: passo 6, imagem 2 %32
    • Carefully untangle the wires that connect the speaker to the motherboard.
  7. Fugoo Tough XL Motherboard Replacement: passo 7, imagem 1 %32 Fugoo Tough XL Motherboard Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the two ribbon wires on the left and right side of motherboard.
    • Do not pull the cables by the cord, as this could damage the cables and the motherboard. It is best to always disconnect the cables from the base, which is closest to the motherboard, using an iFixit opening tool.
  8. Fugoo Tough XL Motherboard Replacement: passo 8, imagem 1 %32 Fugoo Tough XL Motherboard Replacement: passo 8, imagem 2 %32
    • There is a hidden ribbon on the motherboard, that becomes visible once the motherboard has been pulled out.
    • Pull the motherboard halfway out.
    • Gently unplug the ribbon using tweezers.
  9. Fugoo Tough XL Motherboard Replacement: passo 9, imagem 1 %32 Fugoo Tough XL Motherboard Replacement: passo 9, imagem 2 %32
    • Remove the motherboard and battery.
    • Remove the four 3 mm screws from the motherboard using a 3 mm Hex screwdriver.
Conclusão
Uma outra pessoa concluiu este guia.
Abdul
Membro desde: 02/17/17
527 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S19-G1, Hoffman Spring 2017 Membro de USF Tampa, Team S19-G1, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G1
Membros da 4
Autoria de 5 guias
7 comentários
I would like to know where you purchased a fugoo tough or fugoo tough xl motherboard. Thanks you!!
Rhett Mccrady - Responder
Fugoo Tough XL Motherboard donde la puedo conseguir i que esta costando o que vale muchas gracias
William Javier Aldana -
Hi, I just opened my e-mail and this half information Ifixit was there. Wow, I spent weeks researching to find a motherboard. I called Fugoo and they assisted me with the major difficult project. ITs so simple to disassemble. You unscrew it and open it up. Very well built and engineered Bluetooth Speaker. MORE INFO NEXT COMMENT
change the battery just buy a similar battery and swap out the plugs. Very simple too. All I wanted was original though. The Fugoo speaker is awesome and the best. There customer support is perfect. Although, my only problem was with half information given and the details left out. For example, HOW TO REPLACE BATTERY.. The %#*@ instructions are the same as yours. Its how to take it apart. SO SIMPLE. Did you forget to tell everyone how to get the battery or how to modify one, because you can only get them in china and good luck its impossible. MORE INFO NEXT COMMENT
Amazon has them and the Harmon Kardon is a good replacement ($12)you have to swap plugs is all. And you mister your video is not how to replace a motherboard. Its how to take it apart. then the end. Where in the fxxk you find one is my question, because you did not even show a picture of the new one and where to get it or a picture of it installed.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 1,163
