Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
We're going to replace the batteries in a singing doll. This one happens to be Elsa, but this guide is applicable to many plush dolls that sing!
Ferramentas
Peças
  1. Carefully arrange Elsa's clothing so her body is accessible.
    • Carefully arrange Elsa's clothing so her body is accessible.
    • Find the Voice Module inside the toy's body.
    • Using a seam ripper, open Elsa up near the Voice Module.
  2. Once the seam is ripped, you'll be able to retrieve the Voice Module from inside the toy.
    • Once the seam is ripped, you'll be able to retrieve the Voice Module from inside the toy.
    • The Voice Module is contained inside a small cloth bag -- open it up with the seam ripper.
  3. Carefully pry off the top the Voice Module to expose the electronics inside. Carefully pry off the top the Voice Module to expose the electronics inside.
    • Carefully pry off the top the Voice Module to expose the electronics inside.
  4. Carefully remove the worn LR41 batteries from the Voice Module electronics. Replace with new LR41s, obviously!
    • Carefully remove the worn LR41 batteries from the Voice Module electronics.
    • Replace with new LR41s, obviously!
    • Warning: button batteries are a choking hazard! Dispose of them properly, and away from children.
Conclusão
To reassemble Elsa, follow these instructions in reverse order. Except instead of ripping seams, sew them back up.
Be especially careful to sew securely -- loose batteries are a choking hazard.
2 outras pessoas concluíram este guia.
Dom Santangelo
Membro desde: 19/09/2016
556 Reputação
3 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 68
Duração total: 3,259
