Ir para o conteúdo principal
Front License Plate Installation
O que você precisa
  1. Front License Plate Installation, Front License Plate Installation: passo 1, imagem 1 %32 Front License Plate Installation, Front License Plate Installation: passo 1, imagem 2 %32 Front License Plate Installation, Front License Plate Installation: passo 1, imagem 3 %32
    • Gather your tools. Drill, Sharpie, Drill Bits, Painters Tape.
    • Get the parts, too. The front license plate bracket and the 4 plastic spreader rivets.
    • Don't forget the Touareg :)
    • Use Painters Tape to mark your drill bits at 1/2" of depth - so you don't drill into the bumper too far.
  2. Front License Plate Installation: passo 2, imagem 1 %32 Front License Plate Installation: passo 2, imagem 2 %32
    • Position the license plate frame and center it on the VW emblem and parking camera (below, if installed). You can use the vertical supports in the lower grill (hard to see in this pic) to assist in alignment.
    • Hold the license plate frame in place using some painters tape.
    • Using the Sharpie, mark the four holes that you'll be drilling.
  3. Front License Plate Installation: passo 3, imagem 1 %32
    • Remove the frame for easier drilling.
    • Using the 1/8" drill bit, drill four pilot holes in the center of each position.
    • Finish the holes by enlarging them with the 11/32" drill bit.
  4. Front License Plate Installation: passo 4, imagem 1 %32 Front License Plate Installation: passo 4, imagem 2 %32
    • Place the frame back into position.
    • Install the four plastic spreader rivets.
    • Ensure they are seated by using a socket (as shown) to ensure rivets are fully seated before pushing in the center pin.
  5. Front License Plate Installation: passo 5, imagem 1 %32 Front License Plate Installation: passo 5, imagem 2 %32 Front License Plate Installation: passo 5, imagem 3 %32
    • Tap the center pins of the rivets so they are flush with the rivet body.
    • Use #10 x 1/2" Stainless Steel Screws to affix the plate to the mounting bracket. You can see slight indentations where the screws are to go. I drilled pilot holes first.
    • Don't use the "standard" license plate hardware that is 3/4" long. Those screws appear to be long enough to hit the bumper when inserted.
Linha de Chegada
8 outras pessoas executaram este guia.
Justin
Membro desde: 10/27/12
1.565 Reputação
Autoria de 3 guias
6Comentários do guia
I would like to know where the license plate bracket/frame was purchased.
ruthkoljonen - Responder
Nice instructions! I bought my Touareg from Honda dealer with no front plate holder. They ordered me the holder but it came with no instructions. These were perfect! Thank you!!!
TRENT MATTHEWS - Responder
Really, VW. $45,000+ for an ID.4 and *I* have to drill holes in the body to mount the license. This stinks.
E F Charles LaBerge - Responder
Utter bullshit that this is my task
XXX - Responder
This was immensely helpful and the install went seamlessly. THANK YOU JUSTIN!
I had to go buy an 11/32 bit but that was definitely a perfect size for those plastic rivets.
FYI - if anyone is wondering you need to get the part from your VW Dealer, not from some aftermarket/Amazon outfit. Mine was made in Slovakia same as the car and it fit perfectly.
...and yes, my car was from Alberta, Canada and they only use one plate because they are the renegade province of Canada!!
604Pete - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 76
Ao todo: 28,318
