Ir para o conteúdo principal
Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement
O que você precisa
  1. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement, RCA Male Plug: passo 1, imagem 1 %32
    • Using wire cutters cut the wires and strip 2 centimeters of sheathing from the ends.
  2. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: passo 2, imagem 1 %32
    • Peel the shielding from the wiring to expose the two separate wires.
  3. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: passo 3, imagem 1 %32 Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: passo 3, imagem 2 %32
    • Place 2 - 3 inches of thicker heat shrink tubing over the main wiring.
    • Place 2-3 centimeters of a thinner heat shrink for the individual wiring, where the plastic sheathing was trimmed.
  4. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: passo 4, imagem 1 %32
    • Connect the wires and hold them in place.
    • Due to the lack of complex electronics in the speaker, as long as both wires have a connection, the speaker will work.
  5. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: passo 5, imagem 1 %32 Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: passo 5, imagem 2 %32
    • While the two wires are connected, place the solder metal over the wires.
    • Bond the wires together by pressing the soldering iron over the solder, until the solder covers where the wires connect.
    • Do not to touch the soldering iron or the melted solder until they cool for a few minutes.
  6. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: passo 6, imagem 1 %32
    • Cover the exposed wires with the thinner heat shrink tubing.
  7. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: passo 7, imagem 1 %32 Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: passo 7, imagem 2 %32
    • Use the heat gun to shrink the tubing around the connected wires.
    • Hold the wires with a tool or an oven mitt to avoid burning yourself with the heat gun.
  8. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: passo 8, imagem 1 %32
    • Move the thicker heat shrink tubing over the smaller heat shrink tubing.
    • Use a heat gun to shrink the tubing in place.
  9. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: passo 9, imagem 1 %32
    • Showing the clogged port.
  10. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: passo 10, imagem 1 %32
    • Heat the tip of a thin screwdriver with an average lighter.
    • Use a tool or an oven mitt to hold the screwdriver to avoid any burns.
  11. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: passo 11, imagem 1 %32
    • Hold the screwdriver tip inside the clogged port for 3 - 5 minutes.
    • Using a wrench to hold the screw driver, use a hammer to keep weight on the screwdriver.
    • This allows the screwdriver to melt through any plastic from the RCA male plug and reach the metal tip inside the port.
    • Remove the pin when it has bonded to the screwdriver.
Linha de Chegada
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Ao todo: 188
