Ir para o conteúdo principal
Frigidaire Gallery Water Filter Replacement
O que você precisa
  1. Frigidaire Gallery Water Filter Replacement, Water Filter: passo 1, imagem 1 %32
    • Locate the water filter in the back of the interior compartment.
    • It looks like a long white cylinder.
  2. Frigidaire Gallery Water Filter Replacement: passo 2, imagem 1 %32 Frigidaire Gallery Water Filter Replacement: passo 2, imagem 2 %32
    • Push back on the compartment to remove the filter.
    • The filter will then pop out.
    • Remove the used filter and discard it.
  3. Frigidaire Gallery Water Filter Replacement: passo 3, imagem 1 %32 Frigidaire Gallery Water Filter Replacement: passo 3, imagem 2 %32 Frigidaire Gallery Water Filter Replacement: passo 3, imagem 3 %32
    • Unwrap the replacement filter from its packaging.
    • Insert the replacement filter into the water filter housing.
    • You should hear an audible click when the filter is in place.
  4. Frigidaire Gallery Water Filter Replacement: passo 4, imagem 1 %32
    • Once the filter is in place, close the refrigerator door and press the water button on the freezer side.
    • Run the water for 2-3 minutes, or run approximately 2-3 gallons of water through the system to flush the filter with running water.
Linha de Chegada
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 29
Últimos 30 dias: 215
Duração total: 5,028
