Ir para o conteúdo principal
Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement
O que você precisa
  1. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheels from Frame: passo 1, imagem 1 %32 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheels from Frame: passo 1, imagem 2 %32
    • Use the socket head of the 19mm wrench to unscrew the nut that connects the castor wheel’s fork to the steel frame.
    • Remove the wheel from the small steel frame.
  2. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Unfasten Castor Wheel from Wheel Fork: passo 2, imagem 1 %32 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Unfasten Castor Wheel from Wheel Fork: passo 2, imagem 2 %32 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Unfasten Castor Wheel from Wheel Fork: passo 2, imagem 3 %32
    • Hold the bolt that connects the wheel to the fork with pliers.
    • This keeps the bolt through the wheel from rotating.
    • Use the socket head of the 10 mm wrench in your other hand to remove the nut on the other end of the bolt.
  3. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheel from Wheel Fork: passo 3, imagem 1 %32 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheel from Wheel Fork: passo 3, imagem 2 %32 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheel from Wheel Fork: passo 3, imagem 3 %32
    • Flip wheel over and remove the bolt.
    • Remove the castor wheel.
  4. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Obstructing Debris: passo 4, imagem 1 %32
    • Check for and remove any debris from the wheel or wheel axel that may be obstructing motion.
Conclusão
Uma outra pessoa concluiu este guia.
Alyssa Chaney
Membro desde: 04/22/13
49 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-7, Maness Spring 2013 Membro de Cal Poly, Team 14-7, Maness Spring 2013
CPSU-MANESS-S13S14G7
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 1,398
