Introdução
Follow this guide to remove and replace the Touchpad Module in your Framework Laptop 16.
O que você precisa
Use your fingernail to pull out the two Input Module latches and unlock them.
Use your fingers to slide the Touchpad Module toward the bottom edge of the laptop and disconnect it.
Lift the Touchpad Module and remove it.
Place the Touchpad Module flat on its cutout so its clips are properly aligned.
Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
Conclusão
If you need help, contact Framework support.
