Ir para o conteúdo principal
Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement
  1. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement, Engine Air Filter: passo 1, imagem 1 %32
    • Pull out the hood release in the driver's footwell to pop open the hood.
  2. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: passo 2, imagem 1 %32 Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: passo 2, imagem 2 %32
    • Release the hood latch to lift the hood.
    • To avoid difficulty finding the latch, search near the center of the hood.
  3. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: passo 3, imagem 1 %32 Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: passo 3, imagem 2 %32
    • Position hood prop rod into the support hole.
    • Hoods are heavy and the securement of the prop rod is necessary to prevent injury.
  4. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: passo 4, imagem 1 %32
    • Unlatch the three clips securing the engine air filter cover. (The third clip can't be seen in the photo but is on the other side of the cover.)
    • Be sure to allow the vehicle to cool down before working in the engine bay.
  5. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: passo 5, imagem 1 %32
    • Gently remove the air filter cover.
  6. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: passo 6, imagem 1 %32
    • Remove the filter by simply pulling it out of the filter compartment.
Conclusão
Ahmad Elahi
Membro desde: 01/21/21
169 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 41
Duração total: 763
