Ir para o conteúdo principal
Fossil Speedway Watch TI-5061 Time Setting Dial Replacement
O que você precisa
  1. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Clasp: passo 1, imagem 1 %32 Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Clasp: passo 1, imagem 2 %32 Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Clasp: passo 1, imagem 3 %32
    • Keep clasp in open position.
    • Push one of the spring-loaded pins out of the hole with a Push-pin.
    • Wiggle watch band and clasp till free from each other.
  2. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Back: passo 2, imagem 1 %32
    • Fit the blades of a pair of scissors into the grooves of the screw back.
    • Twist the screw back counter clockwise with the scissors.
    • Once the back is loose enough, you can use your fingers to twist it off.
  3. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Time Setting Dial: passo 3, imagem 1 %32 Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Time Setting Dial: passo 3, imagem 2 %32
    • Press the release button for the Time Setting Dial using a thin pin.
  4. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement: passo 4, imagem 1 %32 Fossil Speedway Watch TI-5061 Time Setting Dial Replacement: passo 4, imagem 2 %32
    • Pull the dial out gently with fingers.
Conclusão
Julia List
Membro desde: 04/21/15
5.625 Reputação
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 31
Duração total: 1,176
