Introdução
This repair guide will show you how to replace the motherboard on a Fossil Q Marshal Gen 2 smartwatch. Be careful not to damage the motherboard, wiring, or the metal connectors on your smartwatch.
O que você precisa
Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
Remove chain from opposing side of watch body.
The battery is secured to the back of the motherboard utilizing a sticky pad. Gently separate the battery from the board while making sure not to put too much stress on the board. This is best done at the location shown.
Using your finger remove the metal hooks from the black electronic housing.
4 outras pessoas executaram este guia.
