Introdução
This repair guide will show you how to replace the battery on a Fossil Q Marshal Gen 2 smartwatch. Be careful not to damage the wiring or the metal connectors on your smartwatch.
O que você precisa
Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
Remove chain from opposing side of watch body.
The battery is secured to the back of the motherboard utilizing a sticky pad. Gently separate the battery from the board while making sure not to put too much stress on the board. This is best done at the location shown.
Remove battery from plastic housing.
Slip wires through large slot in plastic housing to completely remove.
Ciao! Ho un Fossil Q Founder (DW2e) Gen 2. E’ lo stesso tipo di batteria ricaricabile? E’ possibile conoscere il tipo di batteria e dove acquistarla? Grazie 1000, sto impazzendo:-)
16 outras pessoas executaram este guia.
13 comentários
I have read your awesome guide. This is really helpful.
thank you, i did it. But now what. i have no idea where to buy the spare part. hahaha. Help Me :(
I have the exact same battery I need to replace. easy to take out but where do I get the replacement battery??
Help! I can’t find a replacement battery.
Can't find this model number available anywhere in less than 1000 pieces to buy . Kinda disappointed. On my watch the battery swelled and pushed the display out of the casing which made the disassembly easier but now it's just sat in a bag since I cant find a replacement. Ordered one of ebay that showed up when I searched for this and turned out to be a different model with a different connector
Had the exact same issue
same problem, easy to open, but hard to find the replacement battery.
anyone with a link? looks like an intel battery inside…
fossil don`t care about selling the battery`s they just what you to buy a new watch
Anyone find a battery yet?
GeLar Store on AliExpress.
from where can i get the battery plz do you shop to egypt or dubai
I have a Michael Kors Smartwatch MKT5003 (battery dead), that it is manufactured by FOSSIL, do you know which is the compatible model? which is the battery number and where do I get the replacement battery??
I need help, please...
