Ir para o conteúdo principal
Fosera Scandle 200 Solar Panel Replacement
O que você precisa
  1. Fosera Scandle 200 Solar Panel Replacement, Solar Panel: passo 1, imagem 1 %32
    • Open the case by pulling the back tab toward you in a downward motion.
  2. Fosera Scandle 200 Solar Panel Replacement: passo 2, imagem 1 %32
    • Unscrew the two Phillips #2 5mm screws that hold the power cord in place.
  3. Fosera Scandle 200 Solar Panel Replacement: passo 3, imagem 1 %32
    • Use the flat-end of the spudger to pry off the clamp which holds the cord down.
  4. Fosera Scandle 200 Solar Panel Replacement: passo 4, imagem 1 %32
    • Use the soldering iron to melt down the solder on each terminal by holding the tip of the iron against the solder until it becomes liquefied.
  5. Fosera Scandle 200 Solar Panel Replacement: passo 5, imagem 1 %32
    • Gently pull the leads free from the terminals. If they do not easily separate from the terminals, repeat Step 4.
    • Now any solar panel of appropriate Voltage rating can be used to charge the device by soldering the wire leads to the new panel. Try to find a panel with similar specifications to avoid overloading the battery.
Conclusão
Vincent C
Membro desde: 09/23/14
134 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 12-5, Blackwell Fall 2014 Membro de USF Tampa, Team 12-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G5
4 Membros
Autoria de 11 guias
3Comentários do guia
In order to use solar energy efficiently, we need to learn how to store solar energy. Unfortunately, we can only store a small fraction of the sun's energy.
niks adonis - Responder Compartilhar
More information here.
Go to the link.
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 48
Ao todo: 942
