Ir para o conteúdo principal
Fosera Scandle 200 Battery Replacement
O que você precisa
  1. Fosera Scandle 200 Battery Replacement, Motherboard Removal: passo 1, imagem 1 %32
    • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
  2. Fosera Scandle 200 Battery Replacement: passo 2, imagem 1 %32
    • Gently separate the two halves of the casing.
  3. Fosera Scandle 200 Battery Replacement: passo 3, imagem 1 %32
    • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
    • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
  4. Fosera Scandle 200 Battery Replacement: passo 4, imagem 1 %32
    • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
  5. Fosera Scandle 200 Battery Replacement: passo 5, imagem 1 %32
    • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
  6. Fosera Scandle 200 Battery Replacement, Battery: passo 6, imagem 1 %32
    • Remove the four #0 15mm screws to release the battery housing from the case.
  7. Fosera Scandle 200 Battery Replacement: passo 7, imagem 1 %32
    • Take the battery housing and battery out of the casing.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 12-5, Blackwell Fall 2014 Membro de USF Tampa, Team 12-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G5
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 645
