Ir para o conteúdo principal
Foldable Shopping Cart Swivel Wheels Replacement
O que você precisa
  1. Foldable Shopping Cart Swivel Wheels Replacement, Swivel Wheels: passo 1, imagem 1 %32
    • Clear out the area around the shopping cart and make sure it's free of any obstacles.
  2. Foldable Shopping Cart Swivel Wheels Replacement: passo 2, imagem 1 %32 Foldable Shopping Cart Swivel Wheels Replacement: passo 2, imagem 2 %32
    • Set up the shopping cart by laying it down with the back wheels on the floor.
    • While the method described here applies to most shopping carts, please be aware that not all carts may have the exact locking mechanism.
  3. Foldable Shopping Cart Swivel Wheels Replacement: passo 3, imagem 1 %32 Foldable Shopping Cart Swivel Wheels Replacement: passo 3, imagem 2 %32 Foldable Shopping Cart Swivel Wheels Replacement: passo 3, imagem 3 %32
    • Remove a single wheel by pinching the locking mechanism and slide off the wheel with your hands.
    • You may use pliers instead of pinching the locking mechanism if its difficult or hard.
  4. Foldable Shopping Cart Swivel Wheels Replacement: passo 4, imagem 1 %32 Foldable Shopping Cart Swivel Wheels Replacement: passo 4, imagem 2 %32
    • Repeat the process in step 3 to remove the second wheel.
  5. Foldable Shopping Cart Swivel Wheels Replacement: passo 5, imagem 1 %32 Foldable Shopping Cart Swivel Wheels Replacement: passo 5, imagem 2 %32
    • This is how it should look with the wheels completely off.
  6. Foldable Shopping Cart Swivel Wheels Replacement: passo 6, imagem 1 %32 Foldable Shopping Cart Swivel Wheels Replacement: passo 6, imagem 2 %32 Foldable Shopping Cart Swivel Wheels Replacement: passo 6, imagem 3 %32
    • Prepare the new wheels by ensuring the axle is clear from both sides.
    • Ensure the axle is closing in a bit on one end, as this will help lock it in.
  7. Foldable Shopping Cart Swivel Wheels Replacement: passo 7, imagem 1 %32 Foldable Shopping Cart Swivel Wheels Replacement: passo 7, imagem 2 %32
    • Slide the new wheel into the cart.
    • The clear end of the axle should be inserted first.
  8. Foldable Shopping Cart Swivel Wheels Replacement: passo 8, imagem 1 %32
    • Insert the remaining wheel by repeating step 7.
  9. Foldable Shopping Cart Swivel Wheels Replacement: passo 9, imagem 1 %32 Foldable Shopping Cart Swivel Wheels Replacement: passo 9, imagem 2 %32
    • Ensure the wheels are securely locked, and check if you can move the car freely.
Conclusão
anthony s
Membro desde: 03/18/24
196 Reputação
Autoria de 1 guia
Equipe
3 comentários
Where can I get these type of front swivel wheels to purchase?
Maria - Responder
Great tip! Thank you. How do you remove the back wheels? Thank you.
Dawn Campbell - Responder
Where can I get the smaller 3 wheels do they have a one wheel that can go on instead
Marcella - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 22
Últimos 30 dias: 74
Duração total: 788
