Introdução
The main joysticks have springs that help maintain stability and hold them in place. Whenever the switch does not move or is moving on the springs, it could be out of place or worn out.
O que você precisa
On the back of the remote, you will see 6 5mm Phillips #2 head screws.
Remove screws to open the device and reveal the inside. For this section we will be working with the top half of the remote.
1. Replace the spring starting from the bottom holding hook.
2. Slide the plastic "arm" piece back into place.
3. Attach the spring to the arm piece.
Once completed it will look like the image shown here. Re-assemble the controller and test the joysticks to make sure everything is working properly again.
Uma outra pessoa concluiu este guia.
