Ir para o conteúdo principal
Fluke 77 Series III Front Panel Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. Fluke 77 Series III Front Panel Replacement, Front Panel: passo 1, imagem 1 %32
    • Be sure any test leads are out and the multimeter is off before opening the device.
    • Turn the multimeter so it is display side down.
    • Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
  2. Fluke 77 Series III Front Panel Replacement: passo 2, imagem 1 %32
    • Use your Phillips #2 Screwdriver to remove the four black 21 mm Phillips #2 screws.
  3. Fluke 77 Series III Front Panel Replacement: passo 3, imagem 1 %32 Fluke 77 Series III Front Panel Replacement: passo 3, imagem 2 %32
    • Turn the Fluke 77 Series III Multimeter back over so that it is display side up.
    • Pry the front panel from the back panel at the seam.
    • If the front panel does not come off easily, move a plastic opening tool along the seam until the panels separate completely.
Conclusão
Kishan Patel
Membro desde: 01/31/14
734 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 2-10, Amido Winter 2014 Membro de Cal Poly, Team 2-10, Amido Winter 2014
CPSU-AMIDO-W14S2G10
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 90
