Ir para o conteúdo principal
Fluke 77 Series III Dial Replacement
O que você precisa
  1. Fluke 77 Series III Dial Replacement, Front Panel: passo 1, imagem 1 %32
    • Be sure any test leads are out and the multimeter is off before opening the device.
    • Turn the multimeter so it is display side down.
    • Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
  2. Fluke 77 Series III Dial Replacement: passo 2, imagem 1 %32
    • Use your Phillips #2 Screwdriver to remove the four black 21 mm Phillips #2 screws.
  3. Fluke 77 Series III Dial Replacement: passo 3, imagem 1 %32 Fluke 77 Series III Dial Replacement: passo 3, imagem 2 %32
    • Turn the Fluke 77 Series III Multimeter back over so that it is display side up.
    • Pry the front panel from the back panel at the seam.
    • If the front panel does not come off easily, move a plastic opening tool along the seam until the panels separate completely.
  4. Fluke 77 Series III Dial Replacement, Dial: passo 4, imagem 1 %32
    • Hold front panel with both hands, with your thumbs on the dial axle. The dial axle is the metal rod that comes out from the middle of the white plastic rotating piece.
    • Firmly press down on the dial axle to separate the dial from the front panel.
    • If this is difficult to do with your hands, push the dial axle against something hard, like the edge of a table.
  5. Fluke 77 Series III Dial Replacement: passo 5, imagem 1 %32
    • With the dial loosened, pull the white plastic rotating piece until it comes off the dial axle.
  6. Fluke 77 Series III Dial Replacement: passo 6, imagem 1 %32
    • Finally, push again on the dial axle with your thumb while at the same time pulling the dial off the front panel with your other hand .
Conclusão
3 outras pessoas executaram este guia.
Kishan Patel
Membro desde: 01/31/14
752 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 2-10, Amido Winter 2014 Membro de Cal Poly, Team 2-10, Amido Winter 2014
CPSU-AMIDO-W14S2G10
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 86
Ao todo: 3,344
