Ir para o conteúdo principal
Fluke 77 Series III Battery Replacement
O que você precisa
  1. Fluke 77 Series III Battery Replacement, Front Panel: passo 1, imagem 1 %32
    • Be sure any test leads are out and the multimeter is off before opening the device.
    • Turn the multimeter so it is display side down.
    • Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
    Pergunte ao FixBot
  2. Fluke 77 Series III Battery Replacement: passo 2, imagem 1 %32
    • Use your Phillips #2 Screwdriver to remove the four black 21 mm Phillips #2 screws.
    Pergunte ao FixBot
  3. Fluke 77 Series III Battery Replacement: passo 3, imagem 1 %32 Fluke 77 Series III Battery Replacement: passo 3, imagem 2 %32
    • Turn the Fluke 77 Series III Multimeter back over so that it is display side up.
    • Pry the front panel from the back panel at the seam.
    • If the front panel does not come off easily, move a plastic opening tool along the seam until the panels separate completely.
    Pergunte ao FixBot
  4. Fluke 77 Series III Battery Replacement, Battery: passo 4, imagem 1 %32 Fluke 77 Series III Battery Replacement, Battery: passo 4, imagem 2 %32
    • When doing this next step, make sure to remove the battery slowly, so you don't damage the wires connecting the battery to the device.
    • Locate the 9V battery in the lower right corner of the device.
    • Pull the battery out of its terminal.
    Pergunte ao FixBot
  5. Fluke 77 Series III Battery Replacement: passo 5, imagem 1 %32 Fluke 77 Series III Battery Replacement: passo 5, imagem 2 %32
    • Only pull on the metal snaps and battery. Pulling the cords may damage them.
    • Detach the two metal snaps from the battery.
    Pergunte ao FixBot
Conclusão
5 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 2-10, Amido Winter 2014 Membro de Cal Poly, Team 2-10, Amido Winter 2014
CPSU-AMIDO-W14S2G10
4 Membros
Autoria de 10 guias
1Comentário do guia
Easy to understand and all went well!
petruskewichw - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 118
Ao todo: 21,843
