Ir para o conteúdo principal
Fluke 175 Multimeter Fuse Replacement
O que você precisa
  1. Fluke 175 Multimeter Fuse Replacement, Pre-Disassembly: passo 1, imagem 1 %32
    • Turn off meter and disconnect test leads.
    • Warning: To prevent possible electrical shock, fire, personal injury, or damage to the product:
    • Remove the test leads and any input signals before replacing the fuse.
    • Use ONLY fuses with the amperage, interrupt, voltage, and speed ratings specified.
    • Replace the battery as soon as the low battery indicator appears.
  2. Fluke 175 Multimeter Fuse Replacement, Back Cover Removal: passo 2, imagem 1 %32 Fluke 175 Multimeter Fuse Replacement, Back Cover Removal: passo 2, imagem 2 %32
    • Use a Phillips PH1 driver.
    • Remove the 2 bottom screws by turning counterclockwise.
    • Remove the 2 top screws.
  3. Fluke 175 Multimeter Fuse Replacement, Remove Back Panel: passo 3, imagem 1 %32
    • Carefully remove the front panel from the back section.
    • Do not move control knob while device is open.
  4. Fluke 175 Multimeter Fuse Replacement, Remove Fuses: passo 4, imagem 1 %32 Fluke 175 Multimeter Fuse Replacement, Remove Fuses: passo 4, imagem 2 %32
    • Remove and replace fuses.
    • F1 Fuse, 440 mA, 1000 V, FAST
    • F2 Fuse, 11 A, 1000V, FAST
Conclusão
Richard
Membro desde: 09/14/25
109 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 39
