Introdução
Use this guide to replace the fluid in and bleed the air from your Avid hydraulic caliper brakes.
O que você precisa
Remove the wheel of the calipers you are going to bleed, and remove the brake pads.
Install Avid® brake block.
Measure from the center of handlebar to the tip of brake lever. The distance should be no more than 80 mm.
Check to make sure the half-full syringe is free of bubbles and that the tubing clip is closed.
At the caliper, remove bleed port screw using a T10 Torx driver.
Screw is located in the center of the banjo bolt that attaches the hose to the caliper.
Remove port screw and insert the syringe into the fitting.
Open tubing clamp clips on both syringes.
Hold the lower syringe to help prevent any air from entering the caliper body.
Push the lower syringe plunger to move fluid through the system and out into the lever syringe.
Inspect for air bubbles.
Inspect for dirty or contaminated fluid
Push lower syringe plunger until mostly empty of fluid.
Open tubing clamp of syringe at lever.
Pull back on the plunger to create a vacuum, then push the plunger down.
Pull the brake lever slightly and allow it to snap back to help purge any bubbles remaining in lever body.
Repeat this process 10 times, or until no more bubbles appear in the tubing.
