Ir para o conteúdo principal
Floor Pump O-Rings Replacement
O que você precisa
  1. Floor Pump O-Rings Replacement, O-Rings: passo 1, imagem 1 %32
    • Detach the hose from its holder.
  2. Floor Pump O-Rings Replacement: passo 2, imagem 1 %32 Floor Pump O-Rings Replacement: passo 2, imagem 2 %32
    • Hold the base of the pump steady and twist the barrel counter-clockwise by hand until it completely unthreads.
    • If you are having troubles stabilizing the base and twisting the barrel, try standing on the base and using both hands to loosen the barrel.
    • Lift the barrel off the base.
    • When removing the barrel, be sure not to lose the bump stop O-ring. It may stick to the pump base, may be stuck inside the barrel, or may fall out when you remove the barrel.
  3. Floor Pump O-Rings Replacement: passo 3, imagem 1 %32
    • Lift the pump handle until the top cap is expsoed
  4. Floor Pump O-Rings Replacement: passo 4, imagem 1 %32 Floor Pump O-Rings Replacement: passo 4, imagem 2 %32 Floor Pump O-Rings Replacement: passo 4, imagem 3 %32
    • Place the ends of needle nose pliers into the top cap holes and turn counter-clockwise until the cap is loose.
    • Finish removing the top cap by hand.
    • Pull the pump plunger out of the barrel.
  5. Floor Pump O-Rings Replacement: passo 5, imagem 1 %32 Floor Pump O-Rings Replacement: passo 5, imagem 2 %32
    • Use a small flathead screwdriver to remove the plunger O-ring.
    • Use the screwdriver to remove the upper bump stop O-ring.
    • Install new O-rings.
    • Be careful not to over-stretch or cut the O-rings if you are using the screwdriver to install them.
  6. Floor Pump O-Rings Replacement: passo 6, imagem 1 %32 Floor Pump O-Rings Replacement: passo 6, imagem 2 %32
    • Remove the lower bump stop O-ring from the pump base.
    • Remove and replace the base O-ring.
  7. Floor Pump O-Rings Replacement: passo 7, imagem 1 %32 Floor Pump O-Rings Replacement: passo 7, imagem 2 %32 Floor Pump O-Rings Replacement: passo 7, imagem 3 %32
    • Insert the tips of needle nose pliers into the base cap holes and turn it counter-clockwise until it completely unthreads.
    • Remove the base cap from the pump base.
    • Remove and replace the base cap O-ring.
    • Re-assemble the pump using these instructions backwards.
    • Don't forget to set a new bump stop O-ring on top of the pump base before re-installing the pump barrel.
Linha de Chegada
Uma outra pessoa concluiu este guia.
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
1Comentário do guia
I was looking for ideas on how to “make" an O- ring. It can't be that difficult. I'll update when the plan comes together.?
RBizerka - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 35
Ao todo: 6,889
