Ir para o conteúdo principal
Floor Pump Drive Hose Replacement
O que você precisa
  1. Floor Pump Drive Hose Replacement, Drive Hose: passo 1, imagem 1 %32 Floor Pump Drive Hose Replacement, Drive Hose: passo 1, imagem 2 %32 Floor Pump Drive Hose Replacement, Drive Hose: passo 1, imagem 3 %32
    • Use a pair of pliers to loosen the hose pinch by turning it counterclockwise a couple of turns.
    • Continue to loosen the hose pinch by hand until it comes free from its threads.
    • Slide the hose pinch down the tube so that it does not interfere with removing the hose.
  2. Floor Pump Drive Hose Replacement: passo 2, imagem 1 %32 Floor Pump Drive Hose Replacement: passo 2, imagem 2 %32 Floor Pump Drive Hose Replacement: passo 2, imagem 3 %32
    • Using a hobby knife, carefully slice a slit in the bottom of the hose to allow it to slide off.
    • Be careful and go slowly so as not to damage the nipple underneath.
    • Use a metal prying tool or flathead screwdriver to pry the hose up off of the nipple.
    • Remove the hose from the pump.
  3. Floor Pump Drive Hose Replacement: passo 3, imagem 1 %32 Floor Pump Drive Hose Replacement: passo 3, imagem 2 %32
    • Slide the hose pinch off of the end of the old hose and onto the new hose.
    • Be sure that the threaded end of the hose pinch faces toward the open end of the new hose.
  4. Floor Pump Drive Hose Replacement: passo 4, imagem 1 %32 Floor Pump Drive Hose Replacement: passo 4, imagem 2 %32 Floor Pump Drive Hose Replacement: passo 4, imagem 3 %32
    • Use a metal rod or screwdriver to widen the new hose so that it will fit over the nipple.
    • Slide the hose in place.
    • Push down on the hose clamp while twisting it clockwise to thread it in place.
Linha de Chegada
Uma outra pessoa concluiu este guia.
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 31
Ao todo: 2,493
