Ir para o conteúdo principal
Flipper Zero NFC antenna Replacement
O que você precisa
    • Go to Main Menu > Settings > Power.
    • Select Power OFF.
    • Alternatively, you can press and hold the Back-button for around 10 seconds.
    • Confirm by pressing the Right-button.
  1. Flipper Zero NFC antenna Replacement, Remove the microSD card: passo 2, imagem 1 %32
    • Eject the microSD card by pressing it with your fingernail.
  2. Flipper Zero NFC antenna Replacement, Remove the screws: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    Phillips #0 Screwdriver
    $5.49
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
  3. Flipper Zero NFC antenna Replacement, Open the back cover: passo 4, imagem 1 %32 Flipper Zero NFC antenna Replacement, Open the back cover: passo 4, imagem 2 %32 Flipper Zero NFC antenna Replacement, Open the back cover: passo 4, imagem 3 %32
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
  4. Flipper Zero NFC antenna Replacement, Remove the antenna: passo 5, imagem 1 %32 Flipper Zero NFC antenna Replacement, Remove the antenna: passo 5, imagem 2 %32 Flipper Zero NFC antenna Replacement, Remove the antenna: passo 5, imagem 3 %32
    iFixit Opening Picks (Set of 6)
    • The board with the NFC antenna is glued to the bottom cover with adhesive tape.
    • To remove the board, gently pry one of the edges of the board with a plastic pick to peel off the adhesive tape.
    • Gently pull out the rest of the board by hand.
Conclusão
To reassemble your device, follow these instructions in reverse order and apply new adhesive where needed.
Sebastian
Membro desde: 08/19/18
31.055 Reputação
Autoria de 71 guias
3Comentários do guia
Bonjour, où trouve-t'on cette antenne de rechange svp ?
christelle Poulailleau - Responder
Il n'y a actuellement aucune antenne de remplacement officielle en vente, mais vous pourriez acheter un Flipper Zero défectueux sur eBay et l'utiliser comme donneur, ou tenter votre chance sur AliExpress.
Sebastian -
Where can I buy a replacement rfc card itself?
My son broke it changing the cover
C Mac - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 55
Ao todo: 3,263
