Introdução
This guide will show you how to replace the camera lens of your Flip Video.
O que você precisa
Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
With the LCD screen facing away from you, remove the 2 bronze 3 mm screws securing the LCD using the #00 Phillips screwdriver.
Flip over circuit board so the ribbon connector is facing up.
Remove the 2 stainless steel 3mm screws securing the lens to circuit board with the #00 Phillips screwdriver.
Uma outra pessoa concluiu este guia.
