Ir para o conteúdo principal
Flip Video Directional button replacement or cleaning
O que você precisa
  1. Flip Video Directional button replacement or cleaning, Outer Shell: passo 1, imagem 1 %32 Flip Video Directional button replacement or cleaning, Outer Shell: passo 1, imagem 2 %32
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
  2. Flip Video Directional button replacement or cleaning: passo 2, imagem 1 %32
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
  3. Flip Video Directional button replacement or cleaning: passo 3, imagem 1 %32 Flip Video Directional button replacement or cleaning: passo 3, imagem 2 %32
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
  4. Flip Video Directional button replacement or cleaning: passo 4, imagem 1 %32
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
  5. Flip Video Directional button replacement or cleaning: passo 5, imagem 1 %32
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
  6. Flip Video Directional button replacement or cleaning, Flip Video Directional button replacement or cleaning: passo 6, imagem 1 %32
    • Remove the silicone directional pad insert from the front outer shell.
    • Clean the buttons with soapy water before reassembling the device.
    • Make sure it is completely dry before placing back into the device.
Conclusão
Uma outra pessoa concluiu este guia.
Elizabeth
Membro desde: 04/15/10
100 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 26-21, Regan Spring 2010 Membro de Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 1,967
