Ir para o conteúdo principal
Fleetwood Monarch 62" Recurve Bow String Replacement
O que você precisa
  1. Fleetwood Monarch 62" Recurve Bow String Replacement, String: passo 1, imagem 1 %32
    • Remove the broken or damaged bow string.
  2. Fleetwood Monarch 62" Recurve Bow String Replacement: passo 2, imagem 1 %32
    • One end of the new bowstring will have a loop with a larger diameter than the other. Take the larger loop and secure it onto one end of the bow.
  3. Fleetwood Monarch 62" Recurve Bow String Replacement: passo 3, imagem 1 %32
    • Slide the larger loop halfway down the limb of the bow.
  4. Fleetwood Monarch 62" Recurve Bow String Replacement: passo 4, imagem 1 %32
    • Secure the smaller loop onto the other end of the bow.
  5. Fleetwood Monarch 62" Recurve Bow String Replacement: passo 5, imagem 1 %32 Fleetwood Monarch 62" Recurve Bow String Replacement: passo 5, imagem 2 %32 Fleetwood Monarch 62" Recurve Bow String Replacement: passo 5, imagem 3 %32
    • Place your left leg between the bow shaft and the bow string.
    • Place your foot behind the end of the bow touching the ground.
    • Place one hand near the middle of the bow and the other hand on the string, close to the larger loop.
    • Push down on the top end of the bow and slide the larger loop into place.
Conclusão
Enjoy your new bow-string!
Uma outra pessoa concluiu este guia.
Zachery Kail
Membro desde: 09/16/20
121 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 32
Duração total: 668
