Ir para o conteúdo principal
Fixing slider alignment in an iTouchless trash can.
  1. Fixing slider alignment in an iTouchless trash can., Fixing slider alignment in an iTouchless trash can.: passo 1, imagem 1 %32 Fixing slider alignment in an iTouchless trash can., Fixing slider alignment in an iTouchless trash can.: passo 1, imagem 2 %32
    • These sliding panels automatically retract when you approach the trash can, but can become misaligned and will jam if not re-aligned. The second photo shows our retracting panels jammed into place.
  2. Fixing slider alignment in an iTouchless trash can., Remove the deoderizer from the lid.: passo 2, imagem 1 %32
    • I usually remove the batteries to make the cover lighter. Otherwise it is unbalanced and I'm fighting gravity for the entire repair. The center tab on the filter can be depressed and the filter slides out. If not, you can loosen the two screws on the "LOCK" retainer.
  3. Fixing slider alignment in an iTouchless trash can.: passo 3, imagem 1 %32 Fixing slider alignment in an iTouchless trash can.: passo 3, imagem 2 %32
    • You can open the battery compartment by depressing the tab on the left hand side of the picture. Then the batteries pop right out.
  4. Fixing slider alignment in an iTouchless trash can., Split the lid casing.: passo 4, imagem 1 %32 Fixing slider alignment in an iTouchless trash can., Split the lid casing.: passo 4, imagem 2 %32 Fixing slider alignment in an iTouchless trash can., Split the lid casing.: passo 4, imagem 3 %32
    • Remove the four Phillips head screws holding the two sides of the lid clamshell together. The screws are at the bottom of the four holes on the underside of the lid. As the two sides of the lid pull apart, note the orientation of the white wire harness at the sensor end of the lid and gently unplug it.
  5. Fixing slider alignment in an iTouchless trash can., Advance the bead belt in the drive pulley.: passo 5, imagem 1 %32
    • The sliding panels are driven by the bead belt. The good news and bad news is that belt can stretch. You align your sliding panels by the bumping the bead belt forward or backward by one bead at a time until the panels align.
  6. Fixing slider alignment in an iTouchless trash can., Put it all back together: passo 6, imagem 1 %32
    • Re-assembly is pretty simple IF you remember to re-connect the white cable harness in it's original location and orientation. :)
Conclusão
Elven Decker
Membro desde: 04/18/22
291 Reputação
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 22
Ao todo: 412
