Ir para o conteúdo principal
Fixing a scratchy pot/dial
  1. Fixing a scratchy pot/dial, Fixing the scratching noise: passo 1, imagem 1 %32
    • To find what pot is making the noise by turning them to see what ones give a reaction
  2. Fixing a scratchy pot/dial, Cleaning the pot: passo 2, imagem 1 %32 Fixing a scratchy pot/dial, Cleaning the pot: passo 2, imagem 2 %32
    • Pour or spray some isopropyl alcohol into the pot and turn it to help clean the inside
    • Make sure to use as close to 100% purity isopropyl alcohol as you can for the best results!
    • If this doesn't work after a couple attempts you will most likely need to replace the volume pot.
Conclusão
HelloMacOS
Membro desde: 01/24/22
25.144 Reputação
Autoria de 11 guias
Equipe
Repair is War on Entropy Membro de Repair is War on Entropy
Community
Membros da 16
Autoria de 940 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 23
Duração total: 202
