Ir para o conteúdo principal
Fixing a scratchy pot/dial
  1. Fixing a scratchy pot/dial, Fixing the scratching noise: passo 1, imagem 1 %32
    • To find what pot is making the noise by turning them to see what ones give a reaction
  2. Fixing a scratchy pot/dial, Cleaning the pot: passo 2, imagem 1 %32 Fixing a scratchy pot/dial, Cleaning the pot: passo 2, imagem 2 %32
    • Pour or spray some isopropyl alcohol into the pot and turn it to help clean the inside
    • Make sure to use as close to 100% purity isopropyl alcohol as you can for the best results!
    • If this doesn't work after a couple attempts you will most likely need to replace the volume pot.
Conclusão
HelloMacOS
Membro desde: 01/24/22
27.194 Reputação
Autoria de 11 guias
Equipe
Repair is War on Entropy Membro de Repair is War on Entropy
Community
32 Membros
Autoria de 1.571 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 26
Últimos 30 dias: 81
Ao todo: 1,798
