Ir para o conteúdo principal
Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler
O que você precisa
  1. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 1, imagem 1 %32 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 1, imagem 2 %32 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 1, imagem 3 %32
    • Turn your label-maker on its face. Using your thumb, press in and then upward on the fastener located on the side of your device.
  2. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 2, imagem 1 %32 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 2, imagem 2 %32 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 2, imagem 3 %32
    • Remove the batteries from your device.
  3. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 3, imagem 1 %32 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 3, imagem 2 %32 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 3, imagem 3 %32
    • Using a plastic opening tool from your iFixit tool kit, leverage the label cartridge out of your device.
  4. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 4, imagem 1 %32 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 4, imagem 2 %32 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 4, imagem 3 %32
    • Press the label paper back into alignment with the small holders on the right side of the label cartridge.
  5. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 5, imagem 1 %32 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 5, imagem 2 %32 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 5, imagem 3 %32
    • Place the label cartridge and batteries back into your device. Refasten the bottom case of the label-maker.
  6. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 6, imagem 1 %32 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 6, imagem 2 %32 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 6, imagem 3 %32
    • Well done! You have successfully corrected the paper-jam in your Brother PT-90 Label-Maker.
Conclusão
Kaitlyn Abrams
Membro desde: 10/13/16
1 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Ao todo: 906
