Ir para o conteúdo principal
Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm
O que você precisa
  1. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm, Opening the Device: passo 1, imagem 1 %32
    • Flip device upside down and remove the 4 foam pads at each corner.
    • Remove the 4 screws using a Philips Screwdriver.
    • Gently lift the case off of the body and set down in a safe place.
  2. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm, Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm: passo 4, imagem 1 %32
    • Unscrew the 5 screws in the base circuit board.
  3. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the tweezers to slightly lift the circuit board, allowing the cylindrical alarm piece to slide out.
  4. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm: passo 6, imagem 1 %32
    • Check if the wires are secured.
    • If they are not attached, you may re-solder it together. If they are attached, that means it is a faulty alarm and should replace it.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 47
Duração total: 1,369
