Ir para o conteúdo principal
Fixing Epson Stylus Photo 1400 Paper Jam
  1. Fixing Epson Stylus Photo 1400 Paper Jam, Fixing Epson Stylus Photo 1400 Paper Jam: passo 1, imagem 1 %32 Fixing Epson Stylus Photo 1400 Paper Jam, Fixing Epson Stylus Photo 1400 Paper Jam: passo 1, imagem 2 %32
    • The paper indicator light blinks red if a paper jam occurs. It might have an unusual clicking noise.
    • Press paper button to eject paper.
    • If previous step does not work, turn off the printer and proceed to step 2. Else, proceed to step 4.
  2. Fixing Epson Stylus Photo 1400 Paper Jam: passo 2, imagem 1 %32
    • Attempt to remove paper by gently and slowly pulling the paper out from the top.
    • Pull the paper as straight as possible.
    • If this does not work, proceed to step 3. Else, proceed to step 4.
  3. Fixing Epson Stylus Photo 1400 Paper Jam: passo 3, imagem 1 %32 Fixing Epson Stylus Photo 1400 Paper Jam: passo 3, imagem 2 %32 Fixing Epson Stylus Photo 1400 Paper Jam: passo 3, imagem 3 %32
    • Open cover of the printer.
    • Gently pull out the paper through the hatch.
    • If ink cartridge is in the way, gently push it off to the side.
    • Close cover.
  4. Fixing Epson Stylus Photo 1400 Paper Jam: passo 4, imagem 1 %32
    • If you had success in step 1, paper indicator light should now return to the normal color green.
    • If you had success in step 2 or 3, turn on printer and press paper button.
Conclusão
3 outras pessoas executaram este guia.
Xin Chen
Membro desde: 10/12/11
1.105 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 17-11, Regan Fall 2011 Membro de Cal Poly, Team 17-11, Regan Fall 2011
CPSU-REGAN-F11S17G11
Membros da 4
Autoria de 12 guias
2 comentários
hi my printer(1400) won't print anything whenever I try to print it stacks and then two lights starts blinking on the computer it's saying fetal error paper jam please help me
nkumbu namukoko - Responder
My machine is Epson 1500w ,it make an unusual noise when printing to the middle of the paper and stop lwith the red light blinkinig. Please I need heklp
stephen Banguu-Wobnyine - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 6,952
