Ir para o conteúdo principal
Fixed Gear Bike Chainring Replacement
O que você precisa
  1. Fixed Gear Bike Chainring Replacement, Chainring: passo 1, imagem 1 %32 Fixed Gear Bike Chainring Replacement, Chainring: passo 1, imagem 2 %32
    • Slightly loosen the two rear nuts with a 15 mm wrench to give the chain slack.
    • Remove the chain from the worn out chain ring.
  2. Fixed Gear Bike Chainring Replacement: passo 2, imagem 1 %32 Fixed Gear Bike Chainring Replacement: passo 2, imagem 2 %32
    • Undo all five bolts attached to the crank arm with a hex tool.
  3. Fixed Gear Bike Chainring Replacement: passo 3, imagem 1 %32 Fixed Gear Bike Chainring Replacement: passo 3, imagem 2 %32
    • Take the chain ring off through the crank arm of the pedal and swap the chainring of your choice.
    • Keep all five bolts in the same area to prevent losing them.
    • When bolts appear to be rusty, I recommend replacing them with a new set of bolts for the longevity of the drivetrain.
  4. Fixed Gear Bike Chainring Replacement: passo 4, imagem 1 %32
    • Line up the chainring’s hole to the crankset and tighten all five bolts to hold the chainring in place.
  5. Fixed Gear Bike Chainring Replacement: passo 5, imagem 1 %32
    • Lastly, attach the chain back to the new chainring.
    • Before tightening the two rear nuts back together, ensure the wheel is centered and not touching the rear bike frame.
Linha de Chegada
aljndro__
Membro desde: 08/22/23
121 Reputação
Autoria de 1 guia
Equipe
CSU Los Angeles, Team 1-1, Briggs Fall 2023 Membro de CSU Los Angeles, Team 1-1, Briggs Fall 2023
CSULA-BRIGGS-F23S1G1
Membros da 6
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 18
Duração total: 157
