Ir para o conteúdo principal
Fix: makecab.exe runs for 5-10 minutes after every startup
  1. Fix: makecab.exe runs for 5-10 minutes after every startup, Find CBS log files folder: passo 1, imagem 1 %32
    • Find CBS log files folder. The folder usually contains a .log file under 2 GB, and some .cab files.
    Pergunte ao FixBot
    Comentar
  2. Fix: makecab.exe runs for 5-10 minutes after every startup, Remove any .log files larger than 2 GB: passo 2, imagem 1 %32 Fix: makecab.exe runs for 5-10 minutes after every startup, Remove any .log files larger than 2 GB: passo 2, imagem 2 %32
    • Delete, or move away if you want to keep the logs, any .log files larger than 2 GB in the CBS folder.
    • If makecab.exe is currently running and processing the log files, you may need to end it through Task manager.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
6 outras pessoas executaram este guia.
Somnic
Membro desde: 07/13/18
265 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 30
Ao todo: 1,522
