Ir para o conteúdo principal
Fix the Short in the Plug Guide
O que você precisa
  1. Fix the Short in the Plug Guide, Fix the Short in the Plug Guide: passo 1, imagem 1 %32
    • Find the power cord.
    • Make sure that it is unplugged from the outlet. This is to make sure that no power is flowing through and you are not injured.
  2. Fix the Short in the Plug Guide: passo 2, imagem 1 %32
    • Locate all exposed portions of the wire.
    • Tape over any exposed portions of the wire with electrical tape.
    • Use this power cord temporarily.
  3. Fix the Short in the Plug Guide: passo 3, imagem 1 %32
    • Plug the power cord into the outlet and make sure the power cord is connected to the device. If not, connect the power cord to the back of the device.
    • Replace the damaged cable by purchasing a new cable at your local hardware store.
Linha de Chegada
Rosana Cheruvelil
Membro desde: 09/26/12
147 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 7-50, Forte Fall 2012 Membro de Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,551
