Ir para o conteúdo principal
Fix iPhone X Unable to Activate By Jumper Wires
O que você precisa
Vídeo de Apresentação
  1. Fix iPhone X Unable to Activate By Jumper Wires, Jumper Wires: passo 1, imagem 1 %32 Fix iPhone X Unable to Activate By Jumper Wires, Jumper Wires: passo 1, imagem 2 %32
    • The iPhone X has been dropped and can’t work normally. After restoring, the phone can’t be activated. Next, we try to activate the phone with 3uTools.
    • Connect the phone to the computer and open 3uTools. Click Activate Now and Start.
    • The activation normally takes several minutes. After about 20 minutes, the phone is stuck in the activation interface. The phone is still unable to be activated.
  2. Fix iPhone X Unable to Activate By Jumper Wires: passo 2, imagem 1 %32 Fix iPhone X Unable to Activate By Jumper Wires: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Next, we need to separate the motherboard for further check.
    • Put the motherboard on the 165 °C Heating Platform to heat. When the temperature reaches 165 °C, remove the logic board and signal board with tweezers.
  3. Fix iPhone X Unable to Activate By Jumper Wires: passo 3, imagem 1 %32 Fix iPhone X Unable to Activate By Jumper Wires: passo 3, imagem 2 %32 Fix iPhone X Unable to Activate By Jumper Wires: passo 3, imagem 3 %32
    • Clear thermal grease with a Sculpture Knife.
    • After separation, it is found that there are many missing pads. Then we restore useful pads from missing pads with jumper wires.
    • Attach the logic board to the holder and remove tin on the bonding pad with Soldering Iron at 365 °C and Solder Wick.
  4. Fix iPhone X Unable to Activate By Jumper Wires: passo 4, imagem 1 %32 Fix iPhone X Unable to Activate By Jumper Wires: passo 4, imagem 2 %32 Fix iPhone X Unable to Activate By Jumper Wires: passo 4, imagem 3 %32
    • Apply some Solder Paste to the missing pads and apply tin with Hot Air Gun at 340 °C. Clean the bonding pad with PCB Cleaner and apply some Paste Flux.
    • Solder 0.02 mm copper wires to the bonding pad with Soldering Iron. Please be noted that copper wires must be soldered firmly.
    • Clean with PCB Cleaner again and curl the copper wires to make pads with Tweezers and Sculpture Knife.
  5. Fix iPhone X Unable to Activate By Jumper Wires: passo 5, imagem 1 %32 Fix iPhone X Unable to Activate By Jumper Wires: passo 5, imagem 2 %32 Fix iPhone X Unable to Activate By Jumper Wires: passo 5, imagem 3 %32
    • Apply Solder Mask to the bonding pad to fix the copper wires and solidify the solder mask with UV Lamp for 5 minutes.
    • Scrape away excess solder mask with Sculpture Knife to show the copper wires.
    • Next, remove tin on the bonding pad with Soldering Iron at 365 °C and Solder Wick. Clean the bonding pad with PCB Cleaner.
  6. Fix iPhone X Unable to Activate By Jumper Wires: passo 6, imagem 1 %32 Fix iPhone X Unable to Activate By Jumper Wires: passo 6, imagem 2 %32 Fix iPhone X Unable to Activate By Jumper Wires: passo 6, imagem 3 %32
    • Attach the signal board to the Reballing Platform and put the reballing stencil in position.
    • To prevent solder paste from flowing into the motherboard, insert a metal plate.
    • Apply evenly a layer of low-temperature Solder Paste.
  7. Fix iPhone X Unable to Activate By Jumper Wires: passo 7, imagem 1 %32 Fix iPhone X Unable to Activate By Jumper Wires: passo 7, imagem 2 %32
    • After the solder balls are formed, turn the power off and cool the signal board. Apply some Paste Flux and align the logic board with the signal board.
    • Keep heating for 1 minute when the temperature reaches 165 °C. Turn the power off and cool the motherboard.
  8. Fix iPhone X Unable to Activate By Jumper Wires: passo 8, imagem 1 %32 Fix iPhone X Unable to Activate By Jumper Wires: passo 8, imagem 2 %32
    • Then we install the motherboard to the phone. Open 3uTools to activate the phone. The phone is successfully activated.
    • Test other functions and other functions work well.
Conclusão
REWA
Membro desde: 11/24/20
16.964 Reputação
Autoria de 55 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 49
Ao todo: 1,343
