Ir para o conteúdo principal
Fix charging contacts on Roomba Vaccum
O que você precisa
Documento em destaque
  1. Fix charging contacts on Roomba Vaccum, Contacts Repair Kit for Roomba Vacuum: passo 1, imagem 1 %32 Fix charging contacts on Roomba Vaccum, Contacts Repair Kit for Roomba Vacuum: passo 1, imagem 2 %32
    • 1) Flip the Roomba over and remove your side brush.
    • 2) Remove OR loosen the screws holding the black bottom cover on.
    • 3) Carefully position your back plastic cover so that the new nickel caps line up with the rectangle holes of the bottom cover.
    • 4 )With your thumb, push down slowly but with enough force to push down the plastic on both sides of the contact holes. Your thumb will be by the center wheel. Do this for each contact. The new caps will form and fit into the rectangular holes of your bottom plate. You will need to press hard so the bottom plate seats.
    • 5) Once everything is in place, tighten the screws that hold the bottom black cover onto the Roomba.
    • 6) Put your side brush back on.
    • 7) Press down hard on each new contact cap using your thumbs to ensure they are well seated. Send your Roomba home to test or place on the dock contacts
    • There is a YouTube video, but the link is not allowed here. Please look for Roomba Refuge online. Thank you
Conclusão
The new nickel contact covers will protect the original charging plates of the Roomba and reestablish a quality connection to the dock.
Uma outra pessoa concluiu este guia.
2Comentários do guia
This looks like exactly what I need. Are these contacts available somewhere? Thanks!
Robin - Responder
Please see Roomba Refuge on You Tube / E bay
Roomba Refuge & Day Spa Resort -
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 15
Últimos 30 dias: 44
Ao todo: 559
