Ir para o conteúdo principal
Fix a Loose Mounting Dream MD2462 TV Wall Mount
O que você precisa
  1. Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 1, imagem 1 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 1, imagem 2 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 1, imagem 3 %32
    • Remove the two M4x5mm bolts on the back of the TV plate using a Phillips #00 screwdriver.
    • Unplug the TV cables before removing the TV from the wall.
  2. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 2, imagem 1 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 2, imagem 2 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 2, imagem 3 %32
    • Remove the three lag bolts from the wall mount by using a 13mm open-end wrench.
    • If it is too loose, it can just be pulled out.
  3. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 3, imagem 1 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 3, imagem 2 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 3, imagem 3 %32
    • Fill the holes where the screws were secured using drywall spackle.
  4. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 4, imagem 1 %32
    • Locate the wooden studs on the wall using a stud finder or knock on the wall to see if the stud is behind the wall.
  5. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 5, imagem 1 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 5, imagem 2 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 5, imagem 3 %32
    • Use a pencil to mark three holes on the wall.
    • Use a 3/8-inch drill bit to drill three holes at the marked positions.
    • Secure the wall mount into the wooden studs using new screws or bolts.
    • Ensure that all the screws are firmly secured to the wooden stud.
  6. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 6, imagem 1 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 6, imagem 2 %32
    • Test the firmness of the TV wall mount by gently pushing it up and down.
  7. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 7, imagem 1 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 7, imagem 2 %32
    • Gently replace the TV back on the wall mount.
  8. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 8, imagem 1 %32
    • Make sure the TV is secure and well-centered on the wall mount using a spirit level gauge to confirm the inclination.
Conclusão
Uma outra pessoa concluiu este guia.
Emmanuel Emedeke
Membro desde: 09/17/20
184 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 42
Duração total: 5,536
