Introdução
Having trouble with your Fitbit Surge's GPS? Read this guide to learn how to replace the GPS, but keep in mind that you will need to cut the wristband in order to complete this repair and the band cannot be reattached.
O que você precisa
Unscrew all four black 3 mm Phillips screws on the underside of the watch using a T5 screwdriver.
To reassemble your device, follow these instructions in reverse order. Keep in mind that you will need to cut the band for this guide and it cannot be reattached.
3 outras pessoas executaram este guia.
Um comentário
Where do you get the parts to replace the GPS or the screen ?
