Ir para o conteúdo principal
Fitbit Surge GPS Replacement
O que você precisa
  1. Fitbit Surge GPS Replacement, Fitbit Surge GPS Replacement: passo 1, imagem 1 %32 Fitbit Surge GPS Replacement, Fitbit Surge GPS Replacement: passo 1, imagem 2 %32
    • Unscrew all four black 3 mm Phillips screws on the underside of the watch using a T5 screwdriver.
  2. Fitbit Surge GPS Replacement: passo 2, imagem 1 %32 Fitbit Surge GPS Replacement: passo 2, imagem 2 %32 Fitbit Surge GPS Replacement: passo 2, imagem 3 %32
    • Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
    • Note: Part of the band is hard plastic.
    • Caution: Once the band is cut it cannot be reattached.
  3. Fitbit Surge GPS Replacement: passo 3, imagem 1 %32 Fitbit Surge GPS Replacement: passo 3, imagem 2 %32
    • Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
  4. Fitbit Surge GPS Replacement: passo 4, imagem 1 %32 Fitbit Surge GPS Replacement: passo 4, imagem 2 %32
    • Use a PH000 screw head to undo the newly revealed 4 mm Phillips screws that were hidden beneath the glue.
Conclusão
To reassemble your device, follow these instructions in reverse order. Keep in mind that you will need to cut the band for this guide and it cannot be reattached.
3 outras pessoas executaram este guia.
Angela Pitts
Membro desde: 10/11/16
1.187 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-3, Leahy Fall 2016 Membro de USF Tampa, Team 1-3, Leahy Fall 2016
USFT-LEAHY-F16S1G3
Membros da 3
Autoria de 4 guias
Um comentário
Where do you get the parts to replace the GPS or the screen ?
Christine Arends - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 2,961
