Ir para o conteúdo principal
Fitbit Charge HR Vibration Motor Replacement
O que você precisa
  1. Fitbit Charge HR Vibration Motor Replacement, Vibration Motor: passo 1, imagem 1 %32
    • Remove the four 2.9 mm screws from the back of the display using a Torx screwdriver.
    • Remove the back cover from the device.
  2. Fitbit Charge HR Vibration Motor Replacement: passo 2, imagem 1 %32 Fitbit Charge HR Vibration Motor Replacement: passo 2, imagem 2 %32 Fitbit Charge HR Vibration Motor Replacement: passo 2, imagem 3 %32
    • Remove the two 2.9 mm Torx screws holding the circuit board in place.
    • Carefully pry the board out using an opening tool.
  3. Fitbit Charge HR Vibration Motor Replacement: passo 3, imagem 1 %32
    • Remove the motherboard assembly from the device by gently lifting.
  4. Fitbit Charge HR Vibration Motor Replacement: passo 4, imagem 1 %32 Fitbit Charge HR Vibration Motor Replacement: passo 4, imagem 2 %32
    • Locate the vibration motor on the motherboard.
    • Desolder the red and black wires connected to the motherboard from the vibration motor.
    • Red wire is located closer to the outside. Black wire is closer to the inside of the motherboard.
    • Replace with new vibration motor.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 487
