Ir para o conteúdo principal
Fitbit Charge HR Screen Replacement
O que você precisa
  1. Fitbit Charge HR Screen Replacement, Screen: passo 1, imagem 1 %32
    • Remove the four 2.9 mm screws from the back of the display using a Torx screwdriver.
    • Remove the back cover from the device.
  2. Fitbit Charge HR Screen Replacement: passo 2, imagem 1 %32 Fitbit Charge HR Screen Replacement: passo 2, imagem 2 %32 Fitbit Charge HR Screen Replacement: passo 2, imagem 3 %32
    • Remove the two 2.9 mm Torx screws holding the circuit board in place.
    • Carefully pry the board out using an opening tool.
  3. Fitbit Charge HR Screen Replacement: passo 3, imagem 1 %32 Fitbit Charge HR Screen Replacement: passo 3, imagem 2 %32
    • Remove the motherboard assembly from the device.
    • Flip the motherboard over so the screen is facing upwards.
  4. Fitbit Charge HR Screen Replacement: passo 4, imagem 1 %32 Fitbit Charge HR Screen Replacement: passo 4, imagem 2 %32 Fitbit Charge HR Screen Replacement: passo 4, imagem 3 %32
    • Wedge a nylon spudger between the screen and the motherboard.
    • Gently pry the screen up and remove it from the motherboard.
    • Metal spudgers can puncture an unprotected battery and damage components like the motherboard. Always choose a tool that's ESD-safe, such as a nylon spudger or plastic opening tool.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Ao todo: 1,015
