Ir para o conteúdo principal
Fitbit Blaze Display Frame Replacement
O que você precisa
  1. Fitbit Blaze Display Frame Replacement, Wristband: passo 1, imagem 1 %32 Fitbit Blaze Display Frame Replacement, Wristband: passo 1, imagem 2 %32
    • Locate the front LCD screen on your device.
    • Fitbit logo should appear in the bottom center of the screen.
  2. Fitbit Blaze Display Frame Replacement: passo 2, imagem 1 %32
    • Push the screen out through the back of the metal ring enclosure.
    • Use a small amount of force on screen to prevent damage. Use other hand to catch screen.
  3. Fitbit Blaze Display Frame Replacement: passo 3, imagem 1 %32 Fitbit Blaze Display Frame Replacement: passo 3, imagem 2 %32 Fitbit Blaze Display Frame Replacement: passo 3, imagem 3 %32
    • Locate the metal pin behind the wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into the blue rectangle enclosure.
    • Use a small amount of force to avoid damaging the pins.
    • Remove wristband.
  4. Fitbit Blaze Display Frame Replacement, Display Frame: passo 4, imagem 1 %32 Fitbit Blaze Display Frame Replacement, Display Frame: passo 4, imagem 2 %32 Fitbit Blaze Display Frame Replacement, Display Frame: passo 4, imagem 3 %32
    • Locate the pin behind the second wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into opposite direction.
    • Remove wristband.
Conclusão
3 outras pessoas executaram este guia.
Adrian Borrego
Membro desde: 02/20/17
2.242 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S3-G3, Sullivan Spring 2017 Membro de USF Tampa, Team S3-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G3
4 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 11,294
