Ir para o conteúdo principal
Fitbit Alta HR Battery Replacement
O que você precisa
  1. Fitbit Alta HR Battery Replacement, Remove straps: passo 1, imagem 1 %32 Fitbit Alta HR Battery Replacement, Remove straps: passo 1, imagem 2 %32
    • Push in the clip and slide off the strap from each side.
  2. Fitbit Alta HR Battery Replacement, Remove front cover: passo 2, imagem 1 %32
    • Use a spudger to remove the front cover.
  3. Fitbit Alta HR Battery Replacement, Lift display: passo 3, imagem 1 %32
    • Use a spudger to lift the display.
  4. Fitbit Alta HR Battery Replacement, Disconnect heart rate monitor: passo 4, imagem 1 %32
    • Use a spudger to disconnect the cable that connects the heart rate monitor to the motherboard.
  5. Fitbit Alta HR Battery Replacement, Remove screws from motherboard: passo 5, imagem 1 %32
    • Use a hex 0.7 screwdriver to remove the screws from the motherboard.
  6. Fitbit Alta HR Battery Replacement, Lift motherboard: passo 6, imagem 1 %32 Fitbit Alta HR Battery Replacement, Lift motherboard: passo 6, imagem 2 %32
    • Use a spudger to lift the motherboard.
  7. Fitbit Alta HR Battery Replacement, Lift battery and remove innards: passo 7, imagem 1 %32
    • Use a spudger to lift the battery.
    • When the battery is lifted, the connected components (display, motherboard, battery) will come out.
    • Use a soldering iron to desolder the two battery contacts from the motherboard.
    • Ensure positive and negative wires are in the correct positions. There are + and – signs on the motherboard. Red is positive. Black is negative.
    • Use a soldering iron and lead-free solder to solder the new battery to the motherboard.
Conclusão
3 outras pessoas executaram este guia.
Wendy Sato
Membro desde: 11/12/16
229 Reputação
Autoria de 1 guia
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 76
Duração total: 1,730
