Ir para o conteúdo principal
First Act MA2039 Battery Replacement
O que você precisa
  1. First Act MA2039 Battery Replacement, Battery: passo 1, imagem 1 %32 First Act MA2039 Battery Replacement, Battery: passo 1, imagem 2 %32 First Act MA2039 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Press the bottom tab and lift the lid that is marked "9V Battery"
    • Open the lids of both battery cartridges, use a Spudger to lift the 9-volt battery out.
    • Disconnect the attached 9-volt battery from the positive and negative terminal connections to prepare for replacement.
  2. First Act MA2039 Battery Replacement: passo 2, imagem 1 %32 First Act MA2039 Battery Replacement: passo 2, imagem 2 %32 First Act MA2039 Battery Replacement: passo 2, imagem 3 %32
    • Insert a new, fully-charged 9-volt battery to the terminal connections.
    • Link the positive terminal (+) of the 9-volt battery to the positive connection.
    • Link the negative terminal (-) of the 9-volt battery to the negative connection.
    • Repeat the process for the 2nd 9-volt battery in the neighboring cartridge.
  3. First Act MA2039 Battery Replacement: passo 3, imagem 1 %32 First Act MA2039 Battery Replacement: passo 3, imagem 2 %32
    • Insert the 9-volt battery into the cartridge.
    • Press firmly to slide the battery into the cartridge, and close the tab to ensure the battery is secured.
    • Close the tab after the battery is secured, until the tab "clicks" into place.
  4. First Act MA2039 Battery Replacement: passo 4, imagem 1 %32 First Act MA2039 Battery Replacement: passo 4, imagem 2 %32
    • Make sure connections are secure and insert 9-volt batteries into the battery cartridges.
    • Close the tabs until you hear a click.
    • Now, try turning on the power switch. Get ready to rock & roll!
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 29
Duração total: 751
